General & local notes, Solidworks drawing
Hola!!
First time in this group. I'm a drafter/designer and create detail dwg & assembly dwg for a medical device company.
My question: Is there a way to link item number from a local note, to the assembly structure (or anything) so when we add or delete items (from assy.) the general or local notes (item #s) will update?...or Is there a better way?
For exempla:
"...2) FASTEN HOUSING, ITEM 3, TO BASE, ITEM 6, USING NYLON SCREW, ITEM 1 AND WASHERS, ITEM 2, AS SHOWN...."
I know when using balloons, we can set the balloon to "item number" and also setting the BOM to "follow assy. order"
we can add/delete items from the assembly and the drawing will update (balloons).
Thanks.
For exempla:
Thanks.
RE: General & local notes, Solidworks drawing
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
