FR4 PCB CTE vs. Steel screw/nut joint CTE
New to the forum . . .
I am wondering how a .093 thk FR4 board Z direction CTE would compare to a steel screw CTE.
The issue is that there is a heatsink bolted to a .093 FR4 board using a steel shoulder screw and nut.
Any ideas what the CTE mismatch between the bolted joint and FR4 Z direction might be (per C) ?
THanks !
THanks !
RE: FR4 PCB CTE vs. Steel screw/nut joint CTE
