Spline closure
Spline closure
Spline closure
I have a spline which was created by projecting curves onto a surface.  I have joined it to create one curve.  I have measured the distance from endpoint to endpoint, which is 0.  How do I create a closed curve with this?  Info object states that the closure status is open.  I have tried changing the length then editing the endpoint so that the endpoints are coincident, but it is still considered open.
I need a closed curve to perform FiberSim operations with it.
