Please Help with SQL Query.
I have a customer table with ~1 million records.
I have an external application that performs sertain task to the member number. It requires that the member number is exactly 7 DIGITS long (no letters, simbols, only digits) (table is alphanumeric).
There is a record in that table that either has a letter or a symbol.
I was using like '%x%' command where x was every letters and symbols on my keyboard I could find. But what if its smth other than latin?
How would you suggest to find the record that might contain something other than all digits?
Table = CUSTOMERS
Field= MEMBERNUM
Thanks in advance
RE: Please Help with SQL Query.
I found a solution which works on my SQL engine (Firebird 1.5). There it is:
select <primary key>,substring(MEMBERNUM from 1 for 1) from CUSTOMERS where substring(MEMBERNUM from 1 for 1) not between '0' and '9'
SUBSTRING extracts one character from MEMBERNUM and check if this charcater is between 0 and 9 (pay attention that '0' is character 0 and not number 0; same for '9'). Th syntax is:
SUBSTRING( <string expr> FROM <pos> [FOR <length>]).
<primary key> is used to identify the record.
Then you can test for the second position in MEMBERNUM like:
select <primary key>,substring(MEMBERNUM from 2 for 1) from CUSTOMERS where substring(MEMBERNUM from 2 for 1) not between '0' and '9'
and so on until you find that charcter which gives headaches.
HTH
This gives me an SQL error for the first "FROM"..."Token unknown"
Any ideas?
You probably need to specify which SQL you are using. The syntax for SUBSTRING in MSSQL is:
SUBSTRING(MemberNum,1,1)
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
Thanks for your responds.
How do I check which SQL am I running?
We have Borland 6.5 and SQL Explorer 3.0.
Borland 6.5 means, I believe, Interbase 6.5. In this case search for SUBSTR function in UDF library. It is there.
