Integration of Flow
Integration of Flow
Integration of Flow
Here's my problem:
I am measuring the flow rate from a flow meter, the device gives me a 4 - 20mA signal which I am sending to a National Instruments controler.  The flow meter is calibrated in kg/hr, and I need to convert the analogue signal into a totalized flow (kg).
I know this can be done using integration, but I haven't done it before, so I was wondering if anyone has an example of how to to this.
Thanks for your help.
Cooky
