Part Library Checked box
Is there an easy way to take a file that we currently have on a library and signify that it has already been checked?
If we copy it to our job and then alter it, we also need it to show up that it was altered.  This would keep our check process down to a minimum.
As of right now the checkers are checking every single purchased item even though it hasn't been changed in years.
Any help would be appreciated.
RE: Part Library Checked box
That's the way I do it, with PDMW.
If you have SW Professional, it can be done with eDrawings.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
Thanks guys for the info.  We don't have pdmworks but I am curious as to what you meant when you can do it with edrawings.
