Referencing Component Instances In Assembly Family Tables
Is it possible to reference an instance of a component in an assemblies family table?
Also, is it possible to suppress components from an assembly family table?
RE: Referencing Component Instances In Assembly Family Tables
Yes as long as it is part of the family table, you can supress members in the generic and not see them in any of the instances, if you are wanting the parts only in certain instances add them to the table and yes no them. also you can type in part numbers to replace in and out if they are family table members. Warning do not use interchange parts in family tables they will give you trouble.
Tim
