UG 13 to UG NX3
UG 13 to UG NX3
UG 13 to UG NX3
About 4 years ago I spent some time working with UG13 developing programs for CNC Machining (lathe primarily and some mill). 4 years later I'm back in engineering and now were at ver. NX3. I have been putzin around with it a bit but there are very few simularities. Are there any good books out there for UG NX3 training? I need all the help I can get. Right now I am doing all programming manually but it's a heavy load and I need to get the UG going quick.
Thanks Guys,
Bob
RE: UG 13 to UG NX3
hi bob,
there is a UG-CAST which can help you a lot,
in CAST sequentially explained how to do
nagesh
RE: UG 13 to UG NX3
I have used CAST a little but I can only use it at work and my time is limited there. Thanks for the info though.
RE: UG 13 to UG NX3
Paul,
I tried the link above but it appears the the site is no longer available. Check it out and see if it works for you. Meanwhile still looking for all the help I can get.
RE: UG 13 to UG NX3
The link works for me. Steve is good at modeling, but limited on the manufacturing side.
Try www.cadpo.com for their i.get.it web-based training. You can run it from any web browser, anywhere.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
RE: UG 13 to UG NX3
Not sure what the ethics behind it are (or even if the documentation requires a license), but CAST is just a bunch of web pages in a folder on your drive. If you want to review at home, I would copy the folder and read through the documentation at home. It's not like you are taking a copy of UG, you're just taking the manual home. Don't bother with the .prt files.
Terry
RE: UG 13 to UG NX3
Try just going to their homepage.
I checked it out and it doesn't look like the book covers CAM.
http://www.designviz.com
PP
RE: UG 13 to UG NX3
No, it doesn't cover CAM.  It covers modeling procedures and methods.  I don't know of any books covering CAM, but hopefully someone will point you in the right direction.
RE: UG 13 to UG NX3
Link is working now.. Not sure what happened earlier. Checking cadpro.com now.
