40 ft span wood truss
hi...
Just want to verify if a 24" deep wood floor trusses be able to span upto 40 ft?
dl = 25 psf and ll = 40 psf... thanks
noel
noel
RE: 40 ft span wood truss
Check out the "Encyclopedia of Trusses" about half way down.
http://www.trusjoist.com/PDFFiles/1043.pdf
Regardless of what the tables say, you should figure out how to check floor vibrations for this system.
I'd be worried about creep deflection also.
DBD
thanks for the reply guys..
Im actually looking forward to the vibration effects of the trusses and try to see a table that incorporate this effect ,..also how it behaves if double or tripple truss is used instead...
thanks...
noel r guades
