Drilled Displacement Piles
Anyone out there very familiar with these types of piles?
Whats the maximum capacity of a typical pile? How large a diameter pile is typical? I've got a situation where original piles were 50 ton, and I need 70 ton. No piles installed yet, but i'm hoping I can increase the diameter of the pile to get the 70 tons.
RE: Drilled Displacement Piles
http://www.morrisshea.com/dewaal.asp
www.SlideRuleEra.net
And if the allowable load is controlled by the soil or rock then how can they claim 250 tons?
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
On cooling tower job mentioned, (based on geotechnical recommendations) I had specified point bearing, steel HP 12x53 with nominal 40 ton capacity. The Contractor bid the traditionally driven HP, and offered an unsolicited proposal for a one-for-one replacement of the HP with DeWaal piles. Since this Contractor was the low bidder on the specified HP approach, we pursued the unsolicited proposal and negotiated a turn-key design for the DeWaal pile (at a substanial savings). Here is a link to the engineering firm that did the design for that job
http://www.christycobb.com/
I have reason to believe that they have substantial experience designing DeWaal pile projects. Perhaps they can answer your question.
