Steel Lintels and Constructability
This one's been bugging me for a while...
Let's say I have a masonry building or a brick building or a msonry brick building, etc. In this instance, it is manadatory to use a steel W-shape for all lintels. OK, no problem.
How does the mason get the bricks to stick to the lintel? The flanges of the beam are kind of sloped, will the bricks slip off? What kind of surface prep is necessary? Is it common practice to weld some sort of studs onto the lintel prior to bricking-in?
I've watched, obviously not enough, some masonry construction and, always, I miss the completion of the work around the lintels. I've searched the web and all the lintel makers seem to not sell W shapes; they're into cold-formed lintels.
What's a good book for this sort of thing? I would like to see a lot of pictures, etc.
RE: Steel Lintels and Constructability
