Material suggestion for brazing fixture, Please?
We braze tungsten carbide and ceramics at about 1500 F.   We are looking for a rod we can use to move parts around at these temperatures.
A rod maybe 10” long by ¼” diameter (.250”) that we can use to move parts around.
A steel file works fine but gets hot.  We are using porcelain rods we get at a ceramics supply store but they are $3.75 each and snap readily.  We had a tungsten rod recommended but a 7” long by 1/8” diameter rod was $8.25 at the welding store.
Something cheap and strong enough not to snap too readily.
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessor.com
RE: Material suggestion for brazing fixture, Please?
Glass?
We use Silicon Carbide in a similar endeavor.   At first we used some SiC heating elements but settled on SiC kiln furniture, rods, similar to these.
http://www.carbo.com/applications/kiln1.php
How about Alumina tubing?  It's readily available in various sizes.
Another possibility would be TTZ (Transformation Toughened Zirconia) it would be much less likely to break/snap than alumina. And it is suprisingly impact resistant for a ceramic. You can hit it with a hammer and not break it. As to it's cost/availability in rod form, I really can't say however.
