Con rod bearing material
I've a few 500cc air cooled English motorcycle engines, circa 1950, to rebuild.
The original small end bush appears to be of an aluminum alloy.
Can someone recommend a modern bearing material and quote a ASTM or SAE number for the material?
Dick
Dick
RE: Con rod bearing material
This material is available from Atlas Bronze in the USA.
Will
