Convert 2005 part to 2004
I've been working on a project in Solidworks 2005, but our customer is using 2004. Is it possible to save the files as a 2004 file type? Anyone have any ideas?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Convert 2005 part to 2004
Solidworks in not backwords compatible. To be able to save as 2004, you would have to export as a parasolid file, then import the parasolid into 2004. However, you will only have a dumb solid. If you search the forum for backwards compatability you will find many threads on this topic.
The case remains true for Inventor as well so I believe it's not just a SW issue.
Alan M. Etzkorn
Project Develpment Engineer
Wabash National Corp.
www.wabashnational.com
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
To answer your question, No. You will have to use a "dumb" parasolid file to go backwards.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Good point about FeatureWorks, I had forgetten about that one.
Alan M. Etzkorn
