Shut down of Atlas Copco Compresed Air GA37
Dear
I Have problem with this copressed air. when the copmressor is start and after period about from 15-20 min. it suddnely shut down and the message is system failure 11.
Then it should be switch off the main feed power and wait about 5 minutes and then switch on. and then after time the same problem return.
I check the circuit diagram,12V is ok at the terimnal.
Please help me if any body know about this message.
RE: Shut down of Atlas Copco Compresed Air GA37
Follow this link and enter the serial number off of your compressor.
This will take you to the user manual ect.
From there you will be able to find out what the code means.
[url]http
