Three way valve in dosing application
Hello there.
I want to install a manual 3-way valve in the outlet of a dosing pump Prominent Beta and connect polypropylene piping 6/4 mm. I want this in order to select manually in which place the pump will send hyper acid. Can ypu suggest any manufacturer for this kind of 3-way valves ?
Thank you in advance for your time.
RE: Three way valve in dosing application
Panou,
Try posting in Valve Engineering forum408 or in Chemical Process Engineering forum798. What is 'hyper acid'? Sounds like something from a sci-fi movie.
If we learn from our mistakes,
I'm getting a great education!
Look into Novodirect (www.novodirect.de) or Cole-Parmer catalog.Dimensions, materials, prices.
m777182
Parker fittings or Swagelok will have seals and such to handle acids. They will have a valve with the proper seals.
Heres some contact info
http://www.parker.com
http://www.swagelok.com/
Good Luck!!
Quote: "Its not what you know, its who you know" - anybody trying to find a decent job
I used TUFLIN from Germany, HABONIM (Israel) Jemsbury (USA), STAR (Italy). But after some time we all agree that using two "regular" two way valves instaed of one three way is more simple, you do not have to think which direction the valve is open, and have problem if the handle was removed or installed backword.  With two way valves you also have better isolation options and the valves are less expensive and easier to find.
