3D SPLINE
3D SPLINE
I'm using CATIA V5R12 P2, and I am having difficulty in making a 3D SPLINE to use as a rib centerline. Any suggestions?
RE: 3D SPLINE
Be more specific as to the nature of your trouble.
RE: 3D SPLINE
RE: 3D SPLINE
In Autodesk 3D products you can plot the points you need and it will draw a spline with these points.
RE: 3D SPLINE
Before I go deeply over the edge, I'm predicating this example on the assumption that you are truly using the "spline" command, and not the 3D curve function in FreeStyle.
3D splines are created simply by selecting points. You can multi-select points to be used in a spline, either in the tree, or with a window, or you can pick them one by one. You can also impose tangency and continuity constraints. You need to be aware, however, that the spline will be constructed in the order that the points were created. So, you have to be a little clever in how you generate the points. If you are using the points to maintain history, for any reason, it's worth the time to PUT the points in order.
One of the VERY BEST ways to put points into a document with history, is to use design tables, and/or the "GSD point loft spline from excel" function that came with the help docs in versions up to R11. It is available in a modified version on several forums, to account for those of us who either have HD2 license, or for the change in the "OpenBody" label.
Hope that helps. If not, feel free to try again.
RE: 3D SPLINE
When I say "You need to be aware, however, that the spline will be constructed in the order that the points were created," what I mean, is that if you have points 1-7, and you MULTI-SELECT, it will order the points numerically, (by point.value) no matter how funky the spline gets. You can always pick one by one, but unless you are doing just a simple spline, it sort of defeats the purpose.
Again, I hope that helps.
RE: 3D SPLINE
So let me ask this (duh)> "Is there a 3DSPLINE command in CATIA? If so, where is it located."
Terry
RE: 3D SPLINE
Make sure you use SPLINE (with an 'L') and not SPINE (no 'L') - those are 2 different things
RE: 3D SPLINE
It's the last button on the palette.
RE: 3D SPLINE
RE: 3D SPLINE
It will give you the complete guide to Tecumseh markup.
Hope that helps.
RE: 3D SPLINE
RE: 3D SPLINE
I'm using Firefox.
RE: 3D SPLINE
I don't see any forum settings to disable images in a session, so maybe check your install.
RE: 3D SPLINE
RE: 3D SPLINE
Can you see images on other pages?
You might want to check out some of the other *-Tips forums, and see if anyone can answer.
Possibly this forum can help.
Check out CATBlog!
