Residential structural software
Has anyone got a recommendation for structural design software that's set up for residential (stud walls, i-joist floors, truss roofs, lvl and steel beams) framing?
I currently use Enercalc for the beams and joists and ACAD for the drawings.  I would like to find a program that reads an ACAD drawing and can analyze the structural members.
Thanks.
RE: Residential structural software
www.optiframe.com
It has been developed by truss-joist and mitek software.  The license is expensive.
Have you checked the Ram Systems and RISA websites? They advertise wood framing capablities, but I have not looked into their software. WoodWorks is a popular program. Enercalc's web site says they are coming out with a major new software. Their current package is dated, and not very good for wood, so we are using mostly Excel spreadsheets for wood design.
I would not recommend RISA for wood, though it is very good for analysis and steel design.  I can't say for sure but if you want the ability to import a dxf file for analysis then you are probably looking at more expensive software than Enercalc.  Wood works is written to conform with the NDS.  It might be worth a look.  I've never used it myself.
http://www.woodworks-software.com
UcfSE
Can you say why you would not recomment RISA for wood?  I need to design a wood framed structure and I was planning to use RISA.
For usual applications it's ok for wood.  You have a lot of choices for species but you cannot put in built-up members, such as a double 2x4 post or a built-up beam.  It may be that my company just doesn't have the latest version but the code it uses is the 1991 NDS, a bit out dated.  Other than the old code and the problem with doing something other than a single member, RISA works ok with wood.  Anytime I have needed to design something with wood these always bugged me.
Thanks for the replies.  I will look into optiframe.  I've used RISA and found it OK but not what I wanted.  I will also try RAM and woodworks.
Thanks for the help.
The latest version of RISA supports 2001 NDS, multi-ply sections (3-2x4, etc.) and Structural Composite Lumber.
Hey, everyone missed one of the simplest, yet best, software for residential design . . . StruCalc.  There is effectively no learning curve, the cost of the software is quite reasonable, and you will find it useful on at least 80% of your residential work.
By the way, I have no relationship with StruCalc, but I have been using it since version 1, and obtain every upgrade.
Refer to  www.strucalc.com
We use strucalc as well and find it good, except for use with vertical loads only on footings.
Geoff
