Ladder Rungs
Ladder Rungs
I need to find some specific documented information relative to materials that are acceptable to use for ladder rungs, such as ladders used on atmospherice storage tanks, pressure vessels and in general industrial applications. I tried searching OSHA's website to no avail. I have been told that rebar is unacceptable to be used as a ladder rung according to OSHA standards but have seen no such documentation and have seen rebar called out as the ladder rung material on numerous drawings and applications.
Thank you in advance for your help.
Brian
Pressure Vessels and Autoclave Systems
www.mcabeeconstruction.com
The above comments/opinions are solely my own and not those of McAbee Construction.
RE: Ladder Rungs
RE: Ladder Rungs
RE: Ladder Rungs
Brian
RE: Ladder Rungs
The stiles are either 75mm x 10mm, mild steel, flat bar (for intermediate supports spaced at less than 3500mm) or 75mm x 20mm, mild steel, flat bar (for intermediate supports spaced at more than 3500mm)
RE: Ladder Rungs
this may be what you are looking for.
RE: Ladder Rungs
http://www
Brian
RE: Ladder Rungs
RE: Ladder Rungs
'OSHA 1910.27'
I don't have that reg but hope this helps
RE: Ladder Rungs
