Cell height in Hole Table
I cannot adjus cell height of a Hole Table on a drawing. SW does not let me decrease cell height neither by drag nor by entering number. When I try to type cell height, prompt requires me to enter number greater or equival of what I already have.Table is getting bigger then sheet format.
I am using SW 2004, SP0. Any Ideas?
Boris.
RE: Cell height in Hole Table
I don't know if it will help, but you can load newer service packs. SP3.0 is available.
Yanceman
Solidworks is an ugly b*tch sometimes.  If a newer service pack doesn't fix the problem, try opening the table in excel, resizing and reopening it in SW.  It's worked for me.
Good luck
How can I open it in Excel? Where that file is?
R1100S ... I think you are gettting confused with the Excel based BOM. The Hole Table & Rev Table are SW based & although they can be Saved as a TXT or CSV format file, for import into Excel, I know of no way to re-import them back into the SW based tables.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
My mistake, no advice then.
