Center of gravity on assy dwg
   I'm an infrequent user of SW. (Mostly use Pro E) We have SW 2004 SP01. I need to revise an assembly dwg showing the CG. I obtained the CG using Mass Properties in the assembly, but do not know how to transtlate it to appear on the dwg. Any advice would be appreciated.
Thank You,
Matthew J. Brueggeman
Mechanical Designer
National Oilwell Varco
RE: Center of gravity on assy dwg
Check this macro FAQ559-356 it produces a point in a 3D sketch.  This can be viewed in a drawing.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
