Assemblies always loading lightweight
I'm not sure what changed or what I changed, but every time I try to open an assembly, the Load Lightweight box is checked.
Is it possible to turn this off?  I always forget to uncheck the box and my assemblies load lightweight which I don't want.
RE: Assemblies always loading lightweight
Document Properties > System Options > Large Assembly Mode > then make sure Automatically Load Components Lightweight is unchecked.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
I did verify that it is unchecked.  I still have the same issue.  Weird?  What's telling it to load lightweight?
There are other areas on where to check/uncheck Large Assembly mode - Try looking in the other options and see if unchecking it there helps - I don't have the locations in front of me.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
There are two places that Lare Assembly mode can be checked at:
1. Tools-Options-System Options-Large Assembly Mode
2. Tools-Options-System Options-Performance
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
Also when opening from inside SW. The pop up window has a box,"lightweigt" make sure that is not checked.
MWG
 R.G.RAY corp.
Halfmark,
If both of those locations that jksolid listed are unchecked the open dialog box will also be uncheck.  It's a good thing that SWx has commited to doing away with the "light-weight" parts.  We should see this in 2007 or if they do a 2006+.  A side note does anybody know why they have done a XXXX+ release in the past (98+, 2001+)
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
I had the box checked in Tools-Options-System Options-Performance.  I didn't realize it was in two places.
Thanks for the help!
mckeand13, this has been a subject of this forum several times--I even asked it myself once--so it's not as clear as it should be quite yet.
Heckler, SW used to have a policy (or at least used it in advertising) of having two major releases/year.  These releases had to be called something, so the second of each release had a plus after it.  They've since dropped the rigorous release schedule.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Jeff,
If I remember correctly they released 98+ instead of 99 then released 2000.  I remember 2000 being a nightmare one of the first years they integrated Excel in drawings.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
Releases are approx every 10 months now. There may be a 2006+ for 64 bit at end of the year.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
