Reload Sheet Format
Reload Sheet Format
Reload Sheet Format
Has anybody experienced this problem? We recently changed our titleblocks and updated the sheet formats for our different templates, when an old style drawing is opened and you reload the template with the new sheet format the Rev Table always defaults to Letters. Our new format has the Rev Table using numbers and when you create a new drawing from the template it will use Numbers in the Rev Table like it is supposed to, it is only when you reload the format from old to new it comes across as letters. I have verified this on multiple computers and different SP's.
3.0 Ghz
1 GB Ram
SW 2005 SP 1.1
Quadro4 980 XGL
I am running 1.1 because of system instability on 3.0 have not tried 3.1 yet.
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
RE: Reload Sheet Format
The Revision Column in the Revision Table always letters by default...I wonder how you have your Table making numbers at all.
Tools->Options->Document Properties->Tables.
There is an option there to change Alpha/Numberical control on revision tables.  We are having a similar problem here, we have the dwg template saved with the numerical option, yet letters keep coming in.
SolidWorks 2005 SP01.1
Intel Xeon 2.8GHz 2GB Ram
NVIDIA Quadro FX700 128MB
The Revision Table has always been able to use either Alpha or Numeric notations.
See settings under Tools > Options > Document properties > Tables
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
Heckdogg,
That is what I have them do when they replace the old Titleblock with the new one, I have them switch from letters to numbers. It just bothers me that it works correctly when you create a new drawing it is setup to use numbers.
