st/stl coil source
st/stl coil source
I am looking for a supplier of coiled stainless steel exactly like that found in common tape measures. Specifically I am seeking the formed shape that tends to straighten when uncoiled but rolls easily when flattened. I have searched for hours to no avail and our needed quantities hardly justify tooling costs to have this strip made.
For prototype and proof of concept, the strip from a 50' tape measure was cannabilized and worked perfectly. Now I just need the raw material.
Any recommendations would be greatly appreciated.
RE: st/stl coil source
www.ulbrich.com
who advertises for hard to find rolled stainless steel
http://www.welding-advisers.com/
h
htt
http://www.theis-usa.com/stainless.htm
Didn't one of the Mariner or Viking stalites use such a system for deploying its antena?
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Not being into radio other than operating certain aspects of the equipment, while in the Army we used a large extendable antenna in 1950's. This particular antenna had four extendable components configured in a diamond pattern. The extendable component would extend 20-25 feet vertically. The was another one that was part of “?Ground Plane Antenna?” that may have extended a little further.
