Need to mount a #10 straight thread AN O-Ring fitting
I need to mount a #10 straight thread AN O-Ring fitting into a wall. The threads are no problem (standard) but I need the dimensions for the O-Ring seating area. These fittings don't have a pocket for the O-Ring. The fitting face is just flat and the mating surface is supposed to have the pocket.
Anybody have this information?
Kevin Jackson
Kevin Jackson
RE: Need to mount a #10 straight thread AN O-Ring fitting
k
Thanks Again, Problem Solved,
Kevin
P.S. I need a -5 AN Straight Thread O-Ring Male Plug, if anybody can suggest a source please do.
Kevin
