Engine friction comparison
How can I compare engine friction for a range of engine types, sizes and maximum revs? I don't need an exact friction calculation but some rules such as 2x cubic capacity = 2x the friction would be very helpful, also how does friction scale with revs. Also I would like to factor in in compression ratio.
I want to use published data of different engine configurations and power / torque curves to assess which designs have the lowest friction.
E.g. compare a V6 and a V8 of similar capacity and max power but produced at different revs and compression ratio.
Regards, Ian
Regards, Ian
RE: Engine friction comparison
http:/
which has proved very useful.
Regards, Ian
