MTEXT IN ACAD 2005 FREEZING UP
AFTER SEVERAL ENTRIES IN ACAD 2005 MTEXT, THE PROGRAM FREEZES EVEN WHEN OPENING UP A NEW DRAWING? WHY AND WHAT CORRECTION IS AVAILABLE?
RE: MTEXT IN ACAD 2005 FREEZING UP
One possiblity is that one or more ACAD files have become corrupted.  Under files>drawing utilites select recover.  Hopefully, this command will restore your files or say they are corrupted.  If ACAD system files are corrupted and not recoverable then I would suggest that restalling ACAD on your system.  Hope this helps.
John
To cadstudent: problem solved by reloading acad 2005;thks for your input!!!
