Any difference between lift stations and pump stations?
I've just started working with a construction company (in the office) and was wondering if there is any great differences between lift stations and pump stations. Is it just applications? Are there any significant cost differences for similar setups?
hartz
hartz
RE: Any difference between lift stations and pump stations?
As for cost differences the question is a nonsense.
No, there is no great difference between the two.
A lift station will raise the liquid a few feet or meters and pump it a SHORT distance to a gravity line or other process.
A pump station does the same thing, only it may pump the liquid a LONG distance.
Not enough difference to worry about.
good luck
I've never heard of a water (as in drinking water/raw water) pump station being called a "lift station", however.
How about alluvial wells? Any other nomenclature commonly used for them. Static well??
h
http://www.abb.com/lift-station
Pumps stations are for water, sewage, oil, etc and are generally above ground.
"One pumps and the other one lifts.
They are typically interchangeable. But in my humble opinion, a lift station would refer to a sewage station, and a pump station would refer to a water booster station. However, I have referred to lift station as pump
stations, but never a pump station as a lift station.
Know what I mean."
