Adding .bmp or .p2d file to flat surface in a assembly ?
How do I add a .bmp to an assembly front panel screen that I've drawn in SW without rendering ?
What I've drawn is a console and a frame and a whole mess of other brackets, frames, fasteners, joystick, keyboard, and i've also drawn a rugged flat panel screen, and i would like a data .bmp displayed in the screen area. It works when I use Decal in photoworks, by I want it to apear when I'm rotating the model around?
Printed Circuit Board Designer
Salt Lake City, Utah
Stangs rule!
RE: Adding .bmp or .p2d file to flat surface in a assembly ?
What you need to do is to insert a texture on the surface of the display screen. In order to do so you will need to do this...:
To create custom textures:
1-Create a folder in your installation directory where you want to store texture files.
2-Place any files to use as textures in the folder you created in step 1. The images must be in .jpg, .bmp, or .png format.
3-In the SolidWorks software, click Tools, Options, System Options, File Locations.
4-Select Textures in Show folders for, then click Add.
5-In the Browse For Folder dialog box, browse to the folder you created in step 1.
6-Click OK.
The next time you apply a texture, the folder path appears in the Texture PropertyManager in the Texture File Locations list, and you can select your custom textures.
Hope it helps
Colombo75
Industrial Designer
SW2005 SP3.1
Colombo75
Sr. Industrial Designer
I'll look into that.
Stangs rule!
Basically, you open a sketch on a face of a part, then go to Tools > Sketch Tools > Sketch picture and select an image. The image can then be re-sized & moved to suit.
The part can be placed into an assy with the picture showing.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
