MVI56-MCM to UDC3300 communications
Does anyone have any ladder logic they can share with me for communicating between an MVI56-MCM module in a ControLogix platform to Honeywell UDC3300 controllers (modbus).
RE: MVI56-MCM to UDC3300 communications
Would this be a Prosoft Card? If so there is a softwear disk that came with the card. Warning these cards will Probably take the better part of a week to learn and require alot of asprin. you will also need to determine the commands and address accepted by the UDC3000 then you must decide if the prosoft card will be the master or the slave.
Pass through mode is available but I ave no clue on that one.
TTFN
THE KAT
DASKAT, yes it is a ProSoft card.  The UDC3300 addresses of interest are the loop 1 and loop 2 present value, to start. I have the ProSoft and Rockwell generic examples for using the ProSoft card, I was hoping to find something more specific to the UDC3300 application.
