BOM's Again
BOM's Again
BOM's Again
I have a SW BOM. With-in the P/N column I would like to have one cell not show the part number of that paticular line item. Also this part i speak of is listed as a configuration. I've tried different things within the config properties and in the BOM properties but haven't found a solution. All i want is just the one paticular p/n cell to be blank. Any help would be great
Adam
RE: BOM's Again
no ideas huh?...i'll keep working on it :)
Adam
Solidworks 2005 SP01.1
Windows 2000
RE: BOM's Again
ParaCAD,
Go into the assembly, open the part that you want to show as blank in BOM. In the configuration of the part in question, right-click and select "properties". change the "Bill of Material Options" tab to "User Specified Name" and enter a space (space bar). This will force a blank in the drawing BOM part number field.
Yanceman
RE: BOM's Again
Thanks....works fine.
Adam
Windows 2000
