Boundary from the results of previous step?
I want to enforce a *BOUNDARY condition (displacement) that is dependent on the results of a previous step.
For instance, if I plastically deform a material and then unload the material, plastic deformations exist. I then want to displace a certain node 1 inch based on the results after unloading.
I have tried to  used dummy nodes with the *Equation option, but for this to work, I would have to make the equation active after the previous step. Or does anyone know of a way that I can specify a boundary condition that is a movement from the previous step result and not using the FIXED condition. Any help would be greatly appreciated. Thank you.
RE: Boundary from the results of previous step?
I may be completely missing the point here but isn't it this simple?
*STEP, NLGEOM
[PLASTIC DEFORMATION LOAD STEP]
*ENDSTEP
*STEP
[PLASTIC DEFORMATION UNLOAD STEP]
*ENDSTEP
*STEP
*STATIC
*BOUNDARY
node,dof,,<distance>
*ENDSTEP
Displacements are carried on to the next step. gwolf is correct though you might need a OP=NEW option here and there.
corus
Thank you for the replies gwolf and corus. You are both correct. The problem is that I don't know what the <distance> is. I know what its magnitude has to be in "comparison" the previous step result.
For instance, I want Node 10 to move 1 inch from where it was after Step 2. The problem is I do not know where Node 10 will be after Step 2. I want to run all steps but right now I have to stop the analysis before programming Step 3.
I currently would run Step 2 with a *RESTART, WRITE option, and then perform a *RESTART, READ and displace the node 1 inch from the result of Step 2. It works but being able to program this for the same analysis over night would be beneficial. RIght now, to run my files overnight, I need to get up about every 3.5 hours.
Idea 1: Use a contact definition in your model. Contact area = target position for node
Idea 2:Activate a nonlinear spring in the last step by using *MODELCHANGE,ADD. This spring should act between the node and the target position. Choose nonlinear spring stiffness so that there a huge nodal force if node isn't at target position.
Pam
