250VDC solenoid valve circuit continuity verification
I am modifying the solenoid valve circuit from "deenrgize to actuate" to "energize to actuate" logic of a feed water regulatin valve at a nuclear station. I need to add some sort of low current device to monitor the circuit continuity to assure that the solenoid will operate when logic demands it to operate. Due to real-estate on the control panel my concept to add neon lamps in the circuit is not viable. Does any one have other possible solution?
RE: 250VDC solenoid valve circuit continuity verification
In principle you could bleed a low current, well below the operating level of the solenoid, through the coil and monitor for continuity that way.
If we learn from our mistakes,
I'm getting a great education!
I looked at making something a while back and can't recall any details without my file at work. Ill try to check and see if I came up with anything creative.
