fanuc control all clear function for tool lengths 11m to 16m
is it possible to to preset all the tool lengths in the library to 999,000 to prevent tools 'crashing' into the work space you can press the all clear soft key and it will set all your tool length offsets to 000.000 . can you change this figure if so how and where.. we had to replace a spindle 6 months ago, due to an inexperienced operator not entering a tool length
RE: fanuc control all clear function for tool lengths 11m to 16m
The use of tool offset to cause a crash is just one of the ways an operator can destroy your machine. You cannot protect against all eventualities. The question I pose is how do you train your operators to avoid most of these bad results in the future?
Let me guess about the crash, it occurred on an off shift soon after this new operator had been on days for 2-4 weeks to get trained to run the machine. The day shift operator did all the running and the new operatior watched. The new guy was given all the grunt jobs to do while the day shift operator sat back and ran the machine.
Train your operators properly and test them if necessary before cutting them loose on your machines.
O1
M00(RESET ALL OFFSETS TO 0?)
#100=1
WHILE[#100LT100]DO1
G10G90P#100R0
#100=#100+1
END1
M30
This will set all offsets to zero. Maybe you can modify this to suit your needs?
Dave
Quote:
O1
#100=1
WHILE[#100LT100]DO1 (note: this resets numbers 1-99, if you have more or less, change this value)
G10G90P#100R0
#100=#100+1
END1
M30
This macro would work except you'll need an "L" command and it will depend on if you have offset type A, B or C. For ex:
G10G90L10P#100R0. ( L10 is tool length for type B and C )
Of course, if you want to set to "999.0", then change the G10 line to"
G10G90L10P#100R999.
Quote:
O1
#100=1
G10G90P#100R0
#100=#100+1
END1
M30
Of course, if you want to set to "99.0", then change the G10 line to"
G10G90L10P#100R99.
