Calculation Module
Calculation Module
Calculation Module
Has anyone else been using the Calculation Module?  In using the module for control valve sizing I have found that when calculating values for low flow conditions (around 1000 gpm) the Cv that I get seems to be erroneous.
I used a second program called QuickSize from Dresser and the value calculated was what I expected to see so that led me to believe that the calc module for INtools has an inherent error in it.
Anyone else?
