Is there an easy way to scale all specific blocks?
Hello.
I'm wondering if theres an lisp app to scale all specified blocks (ie. quick select, block name) and scale them by a input value from the insertion point?
Basically I have blocks from a 1/8"-1'-0" (96) then need to be converted to 3/8" = 1'-0" (32) so scale by 1/3.
Any ideas, I know this should be pretty easy.
Matt
Matt
RE: Is there an easy way to scale all specific blocks?
Use quick select then change the scale factor in the change properities.
