Atmospheric tank
Atmospheric tank
I'm a little out of my element here and there is no-one on site to ask (i.e. no qualified person) -looking through info on API 650, API 2000 etc, what governs alterations to a tank, 9 metres high, 9 metres diamter that conatins a slurry ( non flammable. non toxic etc)? - there is a manhole for entering the tank near the bottom - it becomes a major pain to clean the tank out completely (there is still 2 or 3 feet of slurry in the bottom when drained)- the operators want a slot cut in the bottom near the base to aid cleanout- I've been telling them thay just can't cut a slot and weld a patch over it when done but I can't find the proper 'articles' that tell me that- just about everything covers oil, petroleum products etc and not just a water/slurry mix
PS I'm in Ontario if that makes any difference
same issue for a water stoarge tank(open to atmosphere) for fire protection -they want to add a nozzle for a pressure transmitter- same thing- they just want to empty the tank, add the nozzle & everything is fine and dandy! not in my mind
Thanks for any pointers in right direction
RE: Atmospheric tank
Steve Braune
Tank Industry Consultants
www.tankindustry.com
David
In other words, complying with API-653 for the tank modifications you mention would represent good engineering practice, but is not necessarily a requirement.
9m x 9m is not that large a tank, but you still wouldn't want to be in the vicinity if it ever split open.
