TPO/TPE
TPO/TPE
This is probably a newbie question, but what is the difference, if any, between TPO and TPE?
Are they close enough that they can be used interchangeably?
RE: TPO/TPE
TPO is thermoplastic olefin
See here for example
http://w
So TPO is a subset of the class of TPE. Both are generic terms used to describe a range of polymers so you cannot be sure what the properties are when someone says TPO or TPE. You would have to test a particular material to judge suitability for your application.
