2005 linear pattern editing for muliple configurations
How do I edit a linear pattern for multiple configurations in 2005? In prior releases you would simply DBL click the pattern feature which in turn would display the driving dimension variables which you could edit for this configuration. This functionally is no longer available for 2005? Does anyone know how to do this?
RE: 2005 linear pattern editing for muliple configurations
Flores
Enter these as columns(where LocalLPattern1 is the feature name):
D1@LocalLPattern1 which is the number of instances in direction 1
D3@LocalLPattern1 which is spacing in direction 1
D2@LocalLPattern1 which is the number of instances in direction 2
D4@LocalLPattern1 which is spacing in direction 2
HTH
Kevin
