SW error message
SW error message
Has anyone gotten this dailog box (see pic)? It seems to happen when I have excell open, open a DT in SW close the DT then try to reopen the DT while excell is still running in the back ground. Was happening when I was using SP3.0 just upgraded to 3.1 this morn.
[URL=ht tp://img18 4.echo.cx/ my.php?ima ge=failedt olaunchser ver2fg.png][IMG]http ://img184. echo.cx/im g184/3293/ failedtola unchserver 2fg.th.png[/IMG][/URL]
thanks
SW 2005 SP3.1
[URL=ht
thanks
SW 2005 SP3.1
RE: SW error message
This isn't as much a SW issue as it is an Excel Issue.
If you have closed and SW has updated the DT. Then you must close the Excel.exe in the background using Task manager or you will get that error every time.
The problem is your Excel.exe isn't shutting down after you leave Excel. Look to Microsoft as to why this is happening.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Do you agree?
Can I not have a DT and excel worksheet open at the sametime?
No you cannot. This has been a problem for years. You have to be one or the other, because it causes a conflict beteewn Apps.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
One might think our VAR should have know that.
--Veera
