Variety of Heat Treatment
I am a mechanical engineer, and have been asked to suggest heat treatment processes for a variety of materials. Is there a good reference guide out there? That gives you tables of required strength, hardness, etc... for each material with the corresponding heat treatment process.
From my student days I remember the fundamentals for carbon steels, but we did not cover any other specific material.
Cheers,
MJ
Cheers,
MJ
RE: Variety of Heat Treatment
http://www.asm-intl.org/
Click on the bookstore. ASM international has a wealth of books by topic area.
http://www.asminternational.org
Then go to Bookstore, then look for the Heat Treater's Guides.
Cory
nick
have you any information about heat treatment temperature and time of API5L Gr.X60 steel?
My question is about recovery,recristalisation & growth temperature and holding time.(for achieving to fine grain structure of welded groove joint by E8018 electrode in welding area which As per my syudies ,base structure of fusion zone,HAZ and base metal is ferritic and in part of FZ & HAZ areaes Bainitic structure(Witdmanstatan) has been observed.
Please be informed about chemical composition of above mentiond Carbon-Manganese Steel:
%C:Max. 0.26
%Mn:Max. 1.25
%S,P<0.030
Thanks for your help,
Kayvan
Second comment, are you talking about post weld heat treatment or re-heat treatment of API 5L Grade 60 material after welding?
Sub-critical post weld heat treatment is referenced in the ASME Power Piping Code B31.3 (identified as an S-No1 Gr 2 material). For material that is greater than 3/4" in thickness, PWHT is 1100-1200 deg F for 1 hour per inch of material thickness. Re-heat treatment would need to be performed in accordance with the API 5L specification.
To achieve a fine grained HAZ without re-heat treatment, you need to use the GTAW (gas tungsten arc welding) process versus SMAW.
