ER309MoL for Duplex-SS316 joint
Can we use ER309MoL filler wire for welding SS316 and Duplex steel?
RE: ER309MoL for Duplex-SS316 joint
The corrosion resistance of the weld will be less than for either of the base materials.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
