measuring vibration in pool cues and cue wood
I am trying to measure the vibration in the wood used to make pool cues as well as the shape of the stick taper and the materials used in the joint of a 2-piece stick (brass, steel, plastic).  I am trying to investigate the feel in a more quantitative manner.
I have a PC with a 24-bit sound card and have been looking at the capture units that in interface with a PC.
This is a hobby project, so the budget is not big.
Should I be looking at accelerometers or microphones?
What kind of capture unit should I look at?
Any particular software?
What about the sensor/capture unit or sensor/computer interface?
Thanks for the thoughts.
RE: measuring vibration in pool cues and cue wood
I have done tooling analysis with audiophile software and 24-bit soundcard. Trick is to pay $$$ for a microphone, you want best dB for widest range, 20-20kHz is ok, 18-26kHz is better. Try to get one designed for acoustic analysis or professional recording studio not condenser mic (800-12kHz) for teenagers' tape box.
This has a good trial software package: http://www.purebits.com/
Use software to record through soundcard and mic, run FFT on intersting range(s)...this produced very plausible results for my tool theory.
May I suggest strain gauges to pick up the vibration - they will pickup Hz >> than the 20kHz that a microphone does. Also you will get displacement and not just frequency. Easier to mount also.
Sometimes they are available very cheap on eBay.
But given the problem of interest, low frequency is far more important than high frequency. I suggest cueguy does some calculations to work out roughly which modes he is interested in, and thei likey frequencies. My /guess/ is that first lateral will be around 50 Hz, and longitudinal about 1000 Hz or less
Cheers
Greg Locock
