block insertion menu
i am using ACAD 05
when i insert a block there is a pull down menu to select the recently used blocks.  i have since deleted and renamed some of the blocks.  how do i clear this pull down menu?
RE: block insertion menu
Try purging the unused blocks, I would guess that would do it.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
that works, ive never used purge before.
thanks
