Polymers for implantable bio-fuel cells (with electrocatalysts)
I'm going to do polymer screening tests for bio-fuel cells.
The polymers should consist of a neutral matrix (e.g. poly(vinyl alcohol)(PVA) or silicone) combined with some ionic polymers ("polyelectrolytes (PE)", e.g. anionic PEs like poly(stryrenesulfonic acid) or cationic PEs like polyethyleneimine). I'm going to test several representative PEs from each of the following groups:
  strongly acidic PE
  weakly acidic PE
  weakly alkaline PE
  strongly alkaline PE
The PEs should be well miscible with (PVA) or some silicone lieke polydimethylsiloxane (PDMS), stable in physiological ambient and biocompatible (although not critical in screening tests)
Can anybody recommend me some appropriate PEs?
Many thanks in advance!
RE: Polymers for implantable bio-fuel cells (with electrocatalysts)
You might try looking up the work of Prof. Steve Armes at Sheffield University, UK. He's done a lot with different water soluble polyelectrolytes.
