Prominent Beta BT4a
Prominent Beta BT4a
Hi there.
I am running a project which involves the installation of one PROMINENT DOSING PUMP type BT4a (Beta Solenoid Diaphragm Dosing pump). I search in the OEM site and i beleive that this type of pump cannot run with an external signal of 4-20 mA. Can you confirm this ?
RE: Prominent Beta BT4a
If we learn from our mistakes,
I'm getting a great education!
First of all thank you very much for your response.
For me it was clear but the supplier sent it wrong.
I usually take Prominent Gamma/L or Sigma and control the dosing rate with a standard 4-20 mA signal from a PLC analog output. I am afraid that it would be difficult to change a 4-20 ma signal to pulses (20ms each ) and drive the pump.
