type of model
type of model
Can anybody tell me what type of model do I need for a 3D FEA analysis: a 3D surface or a 3D solid model?
RE: type of model
If you would name the CAD package and the FEA software, someone may be able to give you a better idea. You may also want to post this to the FEA forum (forum727).
Garland
Garland E. Borowski, PE
RE: type of model
etc., etc...
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
RE: type of model
Do you have 3D CAD software? If yes, which one?
Or are you looking into purchase?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
RE: type of model
I use ALGOR 13.
RE: type of model
I believe Algor v.13 was the first version to have "FEMPRO". You should be able to open FEMPRO and open an IGES file. If FEMPRO didn't come out until later, then from SuperDraw III go to File: Import: CAD Solid Model. Set the import file type to .igs and try and pull it in.
RE: type of model
(I did not intend to rhyme)
Chris
ctopher's home site
FAQ559-1100
FAQ559-716
RE: type of model
In reply to: "I obtained objects made by 3D surfaces in AutoCAD 2000 and in MDT 6. Can I use these 3D objects to do FEA analysis (entering supports and forces) in order to obtain deformations and Von Misses stresses ?" which is a slightly clearer question, the answer is yes, of course you can.
I believe a clearer definition of the question is needed here before any more advice is given out.
Cheers,
-- drej --
RE: type of model
Chris
ctopher's home site
FAQ559-1100
FAQ559-716
RE: type of model
RE: type of model
You can use the 3D surfaces to build a FE model and get deformations and stresses, BUT, the real question is: will the results mean anything relative to the actual structural response? To answer this question we need a lot more information regarding what you are trying to model, how the model represents the actual structure, and for what purpose are you going to use the results.
Even when a CAD model is meshed and the FE analysis is run sucessfully, the results can still be rubbish (something not always clearly pointed out by software vendors promoting intergrated software packages). Remember, ALL FE analyses are APPROXIMATIONS of actual structural behavior.
RE: type of model
I am a biginner and I try to understand how does Algor works.
Thanks for your explanations.
RE: type of model
How does what work? You need to be a lot more specific and give a lot more information.
RE: type of model
CAD surfaces are sometimes the start of an FE model. Each of us are trying to understand whether those surfaces represent a structure of thin plates or a mass block. The CAD represetation just gives geometry. Now you need to understand the element theories so you know whether to use that geometry in building a brick model, plates, beams...what are you trying to model. AS SWComposites pointed out, if you use beams where you need bricks, your results could be "rubbish".
Algor is a great tool, but you need to understand degrees of freedom, element types, even convergence theories to start to realize the limitations and power of FEA. This is true of any tool, not just Algor.
It sounds like you need a good course in FEA, not just some training using Algor. Even back to your original question of a 3D surface model or 3D solid model...the answer is you can use either one, but do you understand what to do with it when you get it into your FEA package?
