proscow (Materials) |
27 Jun 05 10:07 |
"Qualified Life" is a term used in nuclear power industry for equipment used in Pressurised Water Reactors (mainly). Equipment, eg a valve actuator will be tested by ageing at some temperature higher than the expected service temp to simulate the required lifetime, it will be irradiated to a dose simulating service plus accident, go through operational cycles, be seismically tested and go through a thermal transient to simulate an accident at end of life. Polymeric components are often the life limiting bits and are given a qualified life, after which they need to be replaced, based on testing of the whole component. The testing is expensive so if an actuator is to be used in a slightly different application with say a lower service temperature an estimate of the new qualified life (i.e. service interval) can be estimated using an Arrhenius extrapolation. Activation energies are held in a nuclear industry database. BUT the activation energy can change with temperature, will be different for different EPDM compounds, will be different for different properties. There are activation energies for EPDM varying from <0.8eV to 1.48eV. You can only use the method once you have some ageing data to start with and I would not recommend it unless you understand the significant errors and limitations inherent in the method. EPRI have written reams on the subject. What you actually need to do is specify the operating conditions to the seal manufacturer in detail and ask how often the seal should be replaced. You need to say if the seal is a face seal/rod seal atc, static/dynamic, process fluids (including any contaminants), temperatures with duration and frequency of any cycles, pressure, radiation dose rate (if appropriate).
For the conditions that you quote and if the time at 135C is very limited (a few hours) and very rare (once or twice) and it is a static face seal, I would say that typically qualified life would be 10 years maximum for an EPDM seal. |
