Number & Location of Air Vents in a Hyrdonic System
I am trying to find recomendations regarding the amount of air vents required on a hydronic system serving radiant panels. The system consists of a main hot water supply line coming off of the buildings hot water riser and travelling down a corridor.
What would be reccomended?
- the main supply/return lines be elevated above the branch piping and point source so it is only necessary to air vent the main lines? or,
- the branch piping be elevated higher then the main supply/return lines and drop down to point source? This would require numerous air vents.
Also, is there a benifit to having the branch piping come off the top of the supply line as opposed to the bottom? Would this help with sediment control?
Thanks for your help
RE: Number & Location of Air Vents in a Hyrdonic System
I never go with bottom tapping. I always go up. If space doesn't permit I would go at sides with shoe joint.
Quark, if you go with a top tapping with branch piping don't you find you need more air vents? I would seem like the arrangement may be prone to air lock.
Another question...Does anyone know if standards exists which state that an air vent is required every X number of meters/feet for a given pipe size with a certain flow rate? I have inquired about this information from manufacturers of air vents but have not received any significant information. They continue to state that they are required at the high points but I feel there must be more to it then that.
I don't feel that we should provide multiple air vents with respect to length of the piping.
