Macro Question
Macro Question
Macro Question
I have this macro I got from this forum that saves a part file to an iges format.  It automatically saves it to the folder location that the part is in.  I am going to be using PDM works so I need to have it save it in a different spot.  What do I need to change to get this to work?
Here is the Macro:
Option Explicit
Dim swApp, Part As Object
Dim BoolStatus As Boolean
Dim LongStatus As Long
Dim e As Long
Dim w As Long
Dim Msg As String
Dim PartName, Rev As String
Sub main()
  Set swApp = CreateObject("SldWorks.Application")
  Set Part = swApp.ActiveDoc
    If ((Part Is Nothing) Or (Not (Part.GetType Eqv swDocPART))) Then
        Msg = "A part document must be active to use this command!"
        LongStatus = swApp.SendMsgToUser2(Msg, swMbWarning, swMbOk)
        End
    Else
        PartName = Part.GetPathName
        PartName = Left(PartName, Len(PartName) - 7) & ".igs"
        BoolStatus = Part.SaveAs4(PartName, 0, 0, e, w)
        If BoolStatus = False Then
            Msg = "Failed to save IGS document!"
        Else
'            Msg = "Saved part as " & PartName
'            LongStatus = swApp.SendMsgToUser2(Msg, swMbWarning, swMbOk)
        End If
    End If
    Set Part = Nothing
    Set swApp = Nothing
End Sub
Chris
RE: Macro Question
These two lines are what take the current part path and swap ".sldprt" for ".igs".  Instead of using "Part.GetPathName" to determine your path, set a new path at this point.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: Macro Question
Could you give me an example?  I am not sure I know exactly what I need to do.
Chris
RE: Macro Question
you could just replace those two lines with this one:
PartName = "C:\temp.igs"
RE: Macro Question
I still want to maintain the parts original name just change the location.  Cab you give me an example of that?
Chris
RE: Macro Question
OK, fine.  Try this:
PartName = Part.GetTitle
If Right(PartName, 7) = ".sldprt" Then
End If
PartName = "C:\" & PartName & ".igs"
If you want the file stored somwhere other than the root of your C: drive, just replace C:\ with whatever path you wish.
I'm pretty sure this will work, but I cannot test it right now.  I don't have PDMWorks, either, so that may change something (but I doubt it).
This is really not very difficult...You really should try and learn Visual Basic.  I think VARS give some courses, or you can even take a general VB class.  Also, there are lots of places on the web to help learn VB.
RE: Macro Question
Ok, thanks
I have every intention on learning more about VBA.  I already have a book just haven't had any time to look through it yet.
Chris
RE: Macro Question
Definitely start w/ VBA before you get too deep into macros.  It really helps.
